Re: H Water Pump Woes
Posted by Janicholson on April 21, 2013 at 13:01:11 from (74.60.94.18):
In Reply to: H Water Pump Woes posted by dstates on April 21, 2013 at 12:25:19:
Assuming you are discussing the packing gland nut that compresses the rope, that is pretty normal. It should be tightened such that the ropes are compressed, then the backed off till the hub spins as you describe (1/4 turn or so). It may leak, if so tighten it one flat of the nut each try until it stops. Jim
