Re: H Water Pump Woes
Posted by dstates on April 21, 2013 at 14:46:56 from (173.18.213.205):
In Reply to: H Water Pump Woes posted by dstates on April 21, 2013 at 12:25:19:
No, I'm talking about the bearing clamp nut that is female thread that goes on the outside of the shaft that holds the pulley assembly onto the shaft.
I'm guessing that the spacer between the two bearings is a little too short and I'm loading up the inner race of the bearings when I snug up the nut. If that is the case, I think the only fix is to remove one bearing and seal and try to shim the spacer some. But my first question still stands... How stiff should it be?
