If you have a slide hammer that you can fix to the end of the splined shaft, where you have a shiny bolt screwed in there now, you should be able to pull the bull pinion and that seal housing/brake disc together. There's nothing holding it from the inside. The seal housing has a large o-ring on the outside circumference that is holding it in with the help of many years of buildup.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
