Re: farmall M block questions
Posted by Janicholson on April 21, 2013 at 18:19:26 from (74.60.94.18):
In Reply to: farmall M block questions posted by bigA on April 21, 2013 at 18:07:41:
Exactly. A is the smallest bore, tightest fit later letters are bigger. At the engine assembly station, IH used select fit and had different sleeves to use in each to assure correct fit. Almost all but custom sleeves (from a company like LA Sleeve)have a small range of real sizes near the mid point of the series. An hole labeled with an A will be very snug. Freeze the sleeves and heat the block to just able to touch it to assure getting it in W/O cracking the new Sleeve.
Jim
