Front port in the head connects to the tube going to the top of the governor housing. Rear port in head has pipe connected to it going to the intake pipe on the air cleaner. If you look close the line over the valves has a small hole in it. Supposed to draw air or some of the crankcase mixture of stuff out. Some pullers plug the rear head port and run them without the pipe. Another way is to put a 2 inch long 1/4 inch pipe nipple in the front head hole under the cover. Then get a 400 or 450 valve cover and run a PCV hose from the opening in top of it to the air cleaner pipe. If running a regular air cleaner?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
