It"s a "casting star" used in a process where the new castings are tumbled in large "barrels" along with a quantity of these stars to knock adhered sand off the cast parts..
Quote from a book on foundry work, dated 1915:
"37.
All types of tumbling barrels are charged with a few hundred pounds of small {star shaped white iron castings commonly called stars} or broken pieces of white iron sprues which aid in cleaning the surfaces of the castings. The castings are put in on top of these stars until the barrels are about half full. When they are securely closed the barrels are set in motion and the castings tumbled until they are clean. The average time required to clean the castings is 10 minutes though it sometimes takes a whole day by the ease with which the cleaning is done the operator may know whether or not the iron has been overheated in the furnace and burned The object of tumbling as stated above is to remove the molding sand that adheres to the castings after the molds are shaken out. If the molds are shaken out when the castings are still hot the sand is frequently burned on so strongly that the subsequent rolling does not remove it but leaves a polished enamel of sand on the casting. This coating is due to the oxidation of the iron in the air while red hot and the formation of a silicate of iron with the sand which is really a slag,
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
