Re: Stainless steel bolts, nuts, washers
Posted by Farmalittle on April 22, 2013 at 08:41:08 from (63.142.125.219):
In Reply to: Re: Stainless steel bolts, nuts, washers posted by Russ from MN on April 22, 2013 at 08:30:59:
Ha ha...thanks for catching that...I was mixing thoughts. I meant more resistant to corrosion!
