Evan Mellott from Iowa said: (quoted from post at 09:43:56 04/22/13) I want to make a F-20 duckbill front-end for the tractor I'm restoring. I have located a F-30 duckbill front-end.
I've checked out and compared both a F-20 and F-30 duckbill front end, and the part numbers of the top-half of the "bill" and the lower half of the "bill" are the same.
So what my question is, can I take the 2 halves of the "bill" and gears off the F-30 front end and put them on a F-20 steering shaft and bolster, hence creating a F-20 duckbill front-end.
This may be a confusing question, but thanks for any help. I believe its possible....
I think I understand what you are trying to say.
Yes, it is true that both the F30 and F20 'duckbill' steering gear assemblies are the same. But they will only bolt to the bolster made for the 'duckbill' steering. The 'duckbill' steering gear assembly will NOT bolt to the bolster used with the worm gear steering gears.
I agree with Oldiron29, unless your F20 falls within the correct serial number range to be an original 'duckbill' adding the duckbill steering is not going to make it collectable or more valuable, it will just be a F20 with incorrect steering. That said, if you just want to add the 'duckbill' steering because you think it is cool, then that is totally fine. Just don't try to pass it off as a genuine "duckbill" F20.
This post was edited by Nebraska Kirk at 14:50:39 04/22/13.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
