Re: Stuck Valve
Posted by 36F30 on April 22, 2013 at 17:12:29 from (71.34.162.1):
In Reply to: Stuck Valve posted by slowfolk on April 22, 2013 at 16:35:16:
slowfolk said: (quoted from post at 16:35:16 04/22/13) Any good tips on unsticking a engine valve without removing the head. 1937 Farmall F20
Remove the valve cover and use a good penetrant/atf on the valve stem, I have a plastic deadblow hammer that I hit em with. Just keep thumpin it and it will come loose. Then oil all the valve stems with engine oil while your in there. Replace the felt pad and wicks if they are in bad shape.
This post was edited by 36F30 at 17:13:41 04/22/13.
