Re: Stuck Valve
Posted by Janicholson on April 22, 2013 at 17:20:03 from (74.60.94.18):
In Reply to: Stuck Valve posted by slowfolk on April 22, 2013 at 16:35:16:
Take off the valve cover. use a nozzle straw on a can of liquid wrench or other juice, and spray the valve stems under the retainers where they dissapear into the guides. Use a plastic hammer to tap on the stemin the downward direction (Gentle tapping). Use two small pry bars nder the top coils of the valve spring to aid in pulling up on the stem to move it upward. Juice, tapping and repeated for as long as it takes. Jim.
