Re: Farmall H frame rails
Posted by Owen Aaland on April 22, 2013 at 17:58:25 from (216.47.34.50):
The bolt holes in the frame are spaced father apart on the later frames. You can use the later frames on the earlier tractors by also replacing the rubber motor mount with the cast block the later ones used.
I replaced the frames on our '40 H many years ago because the original mounts had failed and the cranking coupler would no longer slip on to the end of the crankshaft.
