Low ash oil, correct octane gasoline, correct ign timing and do not over look the valve seats. Most of them get loose in the head. A valve transfers most of it's heat to the head through the valve seat. If that seat does not not transfer heat as well as it should, the valve stem carries more heat. This in turn can cause that valve to stick for an instant and torch out. I put in a lot of over size valve seats in the 263 engine, even before IH introduced LOW ASH oil to get me out of the woods on valve burning. This was when we had so called good gasoline also, like 1964, 65. We had the same problems with that very similar engine used in trucks. They used to cup the valves so there was no clearance, reset them and in a couple trips, same old thing. Then IH came with a plate to block off the heat riser in manifold. That helped but was not really a cure. In a truck, drivers just held the pedal to the metal and they melted down. Had the same problem with my inlaws old chev powerglide. Local shop had installed valve seats and they were not tight. It would burn the valve in a couple thousand miles. I was young and learning and didn't recognize the seat problem for a couple of valve job. Cured it though.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
