Posted by Rick Remmert on April 23, 2013 at 20:41:16 from (68.103.4.23):
In Reply to: Re: C hydraulic leak posted by kevin in Minnesota on April 23, 2013 at 19:47:17:
Go back and look in the archives under Super C touch control overhaul. I just did mine back in February. I posted pictures as I did it, so you can see what has to be done on one. You will need a parts drawing of it to see the parts. I think it is o-ring #34 that you have leaking. It does not show the 2 spools in the drawings with the exception of the very end of one of them. I debated if you can just pull the spool out and change the o-ring or not. I elected to remove the whole unit from the tractor and replace all the seals. Also repainted it while it was out. A word of caution, with the arms removed off the front, the unit still weights over a 100 lbs.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
