Re: Early Super M vs. jd 4rw 7000 planter
Posted by NY 986 on April 24, 2013 at 09:24:34 from (67.142.178.21):
In Reply to: Early Super M vs. jd 4rw 7000 planter posted by Zac Martin on April 24, 2013 at 09:13:58:
It will pull it just fine. If the hydraulic pump is wore out then there could very well be an issue with lifting. If the planter has just the one cylinder at the center it is possible to replace the cylinder with one with a wider piston to enhance the lifting power.
