Re: superA clutch locked up
Posted by Janicholson on April 24, 2013 at 19:32:15 from (74.60.94.18):
In Reply to: Re: superA clutch locked up posted by J.Reece on April 24, 2013 at 19:04:30:
Put blocks in front of the rear wheels. Put it in road gear with the clutch blocked down. Put the crank in a position so the handle is sticking to the right when facing the tractor. Hang 100 pounds of sand or? on the crank handle. Remove the starter. Use a brass drift punch or aluminum bar stock, and a 16oz hammer. strike the meat part of the flywheel to vibrate the stuck clutch. (don't use the ring gear, or thin sections or ribs.) Jim
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
