Re: Super C Charging System
Posted by Hendrik on April 25, 2013 at 00:25:49 from (194.53.253.51):
In Reply to: Re: Super C Charging System posted by Sparky70 on April 24, 2013 at 18:56:10:
Gene is very knowledgeable on the Farmall A and B.
In his reply he wrote: "Does the ammeter show discharge with the lite on meter can also be bad.".
He asks you to verify if the ammmeter shows discharge when the tractor's lights are switched on while the engine is off. If not, the ammeter can be bad, or not hooked up correctly.
I recommend to use John T's trouble shooting scheme as posted by janicholson.
HTH, Hendrik
