Re: superA clutch locked up
Posted by gene bender on April 25, 2013 at 01:58:01 from (67.55.226.151):
In Reply to: superA clutch locked up posted by J.Reece on April 24, 2013 at 18:56:30:
If the driving around didnt work. Had a SC once like that and had to split the tractor then had to use chisels to remove the disc from the flywheel there was no way to get that one loose without splitting even had to get the flywheel refaced.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
