Re: Timing for f 20
Posted by nebraska cowman on April 25, 2013 at 03:28:30 from (66.252.116.102):
In Reply to: Timing for f 20 posted by J weaver on April 24, 2013 at 20:22:03:
Actually it sounds like you have it about right. Move the hand lever to where it runs the smoothest. When tractor is not working it should be something less than full advance. You will notice if you pull it hard that it will use more advance then.
