Re: RE: John T. or anyone ( H causing TV interference)
Posted by n9lhm on April 25, 2013 at 10:15:59 from (38.111.252.2):
In Reply to: RE: John T. or anyone ( H causing TV interference) posted by dhallen on April 25, 2013 at 10:04:40:
Are you already using a directional antenna pointed directly at the station"s transmitter? -- if not, if you are using an omnidirectional antenna, that"s one thing you can try to null out the interference.
Otherwise, if the source of the interference is higher level than the signal you"re trying to receive, and coming from the same direction, there"s not much you can do.
Brian, N9LHM
Chief Engineer, WNIT-TV
