how to mount the radiator on the f-20
Posted by SDE on April 25, 2013 at 12:03:06 from (174.124.34.156):
I do not know what type of bushings or pads or bolts are used to fasten the radiator to the frame rails. Do the bolts feed up from the bottom? Does the radiator go directly on to the frame rails or is their a pad between the rail and the radiator? Is there a bushing that goes into the radiator frame? The hole is so much bigger that the hole in the frame rail. I hope to pick them up at Le Sueur, if i can find them
Thank you
Steve
