Re: carburetor setting SuperA
Posted by Janicholson on April 25, 2013 at 12:10:58 from (199.17.6.160):
In Reply to: carburetor setting SuperA posted by J.Reece on April 25, 2013 at 12:03:53:
The only way to change the main jet value is to change the jet 9non adjustable). The Idle Mixture is set to a combination of low Idle speed and best running. It is not set by the turns. Jim
