Re: carburetor setting SuperA
Posted by pete 23 on April 25, 2013 at 15:38:13 from (74.47.40.242):
In Reply to: carburetor setting SuperA posted by J.Reece on April 25, 2013 at 12:03:53:
Even though it has an adjustable main jet , the jet size is most likely still calibrated for full load so you only lean it slightly but not enrich it beyond what factory determined to be correct for full load. Not saying that jet can't be replaced or drilled for a larger size. If you turn it out a few turns and tractor does not run rich with some black smoke it is no doubt a calibrated jet.
