Re: Re: How to get a piston un stuck?
Posted by Ted on November 16, 2000 at 16:23:39 from (152.163.213.201):
In Reply to: Re: How to get a piston un stuck? posted by Ben on November 11, 2000 at 19:42:07:
I've had real good luck with a stuck engine by installing the air pressure adapters sold at the auto parts store to pressurize your cylinders during valve oil seal changes. I have a grease fitting installed in the air inlet end and the other end that particular spark plug size(the adapters are sold in two's to fit two different plug sizes) and attaching a common hand pumped grease gun the grease fitting and filing the cylinder with grease. You can exert up to 1300 pounds per square inch while pumping in the grease. A little oil in the cyclinder to help fit the void, takes less grease that way helps also. Good luck - mine all have came free this way.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
