Re: 504 diesel balance shaft assembly
Posted by pete 23 on April 26, 2013 at 10:59:23 from (74.47.40.242):
In Reply to: 504 diesel balance shaft assembly posted by binder560 on April 25, 2013 at 17:03:47:
The 504 runs a bit faster than older 4 bangers. Balancing the crankshaft will help but it will not eleminate the inherent out of balance that a 4 cyl engine has. Because that engine is relatively long stroked for size of bore and rpm you may reach the critical vibration point and cause severe damage, like broken crankshaft. If you can get your hands on a original IH service manual for that engine, it gives a very good explanation of the balance needs. Too much to explain here but quick reason is piston travels different distance over a given degree of crankshaft travel at top than it does at bottom of stroke.
