Posted by Matt (NEIA) on April 26, 2013 at 20:20:47 from (184.97.44.110):
Started the 460 gas for the first time today in probably 4 months. It ran good at half choke for about 30 seconds then died, i tried to start it again but the engine just turned over. Thought maybe flooded it so i let it sit for an hour but it still just turns over. Fuel tank is full of gas, additive was added when parked before winter. I unscrewed the carburetor drain plug and just a little bit of gas came out, like a half teaspoon at most. I then started to unscrew the outside flange nut that holds the fuel line to the carb and before i got it all the way unscrewed gas started to run at a good stream. My question is... do I have a problem in my carb? shouldn't gas be running freely out of that drain plug on the bottom of carburetor? I havn't checked for spark but that shouldn't be the problem since it ran fine for 30 seconds correct??? Thanks for any help!!!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
