Re: 140 wont start
Posted by hayfarmer on April 27, 2013 at 08:33:49 from (71.80.194.62):
In Reply to: 140 wont start posted by Markin mo on April 27, 2013 at 08:27:55:
3 things an engine needs to run, spark, compression and fuel. You have spark and if tractor has been running we can assume compression. Have you removed spark plug wires, could they be switched. I would check fuel flow to carb. remove line at carb to see if there is a good flow of fuel there. If not work back toward the fuel tank to find stoppage.
