Re: transmition oil
Posted by speed bump on November 16, 2000 at 21:10:50 from (132.158.129.115):
In Reply to: transmition oil posted by George's H on November 16, 2000 at 18:15:09:
Hi George,6 gallons of 80w90 gear oil for the trans. the pto shaft is allways in this gear oil. maybe you mean the belt pulley housing. it uses the same also by a splashing affect , but if you drain in just add about a half quart. a hint , when you pull the plug to drain old gear lube have 2 5gallon pales ready because it might have a lot of water in their.
Post A Followup
: Re: Re: transmition oil
