Re: seed plate drive
Posted by Jim Becker on April 27, 2013 at 21:27:29 from (173.74.120.222):
In Reply to: seed plate drive posted by tuckaway on April 27, 2013 at 18:50:43:
Did you just install this or has it been on and just started leaking? It doesn't seem like there is really any path for oil to come out next to the bolt.
As I recall, the bolt should go through a special flat washer, then the bushing (the part the sprocket pins to) then goes directly into the end of the axle with no other parts in the stack. When bolted in, the bushing should be tightly held to the axle, no wiggle. Some improper assembly or the bolt running loose might create a path for oil to get out.
