Re: Farmall Generator wiring
Posted by Janicholson on April 27, 2013 at 22:06:11 from (74.60.94.18):
In Reply to: Farmall Generator wiring posted by Nathan Rigg on April 27, 2013 at 21:43:50:
On a farmall with no original lights, the cutout relay had (or has) a third terminal. this is labeled F. it connects to the Field terminal on the gen. It is a fixed wire wound resistor directly to ground. This system allows the generator to charge enough to keep the battery charged but that is all. It does not change the charge rate. With a Magneto, and with no lights the charge rate is usually about 7 volts. Maybe a little less. If your cutout has no third terminal it is the wrong one. If your tractor has a voltage regulator it would be attached in a similar manor to the 3 terminal cutout. It might have a 4th terminal which would be an L terminal standing for load. (it would poewer the lights and ignition (if it had a points and coil type ignition.) Jim
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
