Posted by mkirsch on April 28, 2013 at 07:03:15 from (67.253.161.186):
In Reply to: Starter on 1944 H posted by Jim Paterson on April 28, 2013 at 04:13:00:
Take the dust cover off the brush end of the starter and see if it's actually turning over when you turn the engine.
If it does, then it needs to come off. The starter drive gear should spin back and forth on the shaft easily, and retract towards the motor by spring pressure.
Don't "lube it up" because lube just attracts dirt and crud and makes things worse. Clean and dry is better than slobbered up.
Since you'd have it apart, it would make sense to just replace the whole drive end.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
