Re: change to alt on super a
Posted by mkirsch on April 29, 2013 at 04:59:00 from (64.80.110.74):
In Reply to: change to alt on super a posted by lovell on April 28, 2013 at 10:28:53:
The A/B/C series are the easiest to convert.
An alternator should just bolt right in place of the generator with little to no modification, and use the same belt.
Wiring is the most difficult part but even that is pretty easy. Make sure you get the plug pigtail for the Delco 10SI if that's what you get.
1. Swap the wires on the ammeter.
2. Connect the BAT and L wires off the old regulator to the BAT terminal on the alternator.
3. Connect the #2 terminal on the alternator to the BAT terminal on the alternator.
4. Install a ballast resistor, or preferably a 12V coil (marked no ballast required).
5. Run a wire from the ignition switch to a diode, and connect the "line" side of the diode to the #1 terminal on the alternator.
It's really that simple.
