Re: change to alt on super a
Posted by old on April 29, 2013 at 10:44:11 from (209.86.226.18):
In Reply to: Re: change to alt on super a posted by teddy52food on April 29, 2013 at 09:58:58:
Well it is a mix of both from what I was taught. With out current you have very little but with out the volts to push the current you still have nothing to to play hand in hand. The way I was taught voltage is the pressure and current or amps was the amount sort of like water. You have the voltage or with water thew pressure and then the amps is the amount or size of the flow rate
