Charge the battery for over night at a slow charge rate 6 amps or so. Start the tractor and run it at 3/4 throttle. Put a volt meter across the battery poles to see what the charge voltage is. (should be 14 volts to 14.6volts. If 12.6, the charging system is not working. if the volts are good, the battery might be going bad, or is bad. If charging as above, shut off the tractor and disconnect one of the battery cables and measure voltage between that cable and battery post. If more than 150ma, it has a parasitic drain of some sort. If less than 150, it is another indicator of a bad battery. If the drain is there, disconnect the alternator Bat lead and see if the drain goes away. if so the alt is failing. If no change, remove fuses, and or disconnect and reconnect things looking for that which stops the drain. If no drain, measure battery voltage with the cable removed. if less than 12.3 that is also a battery issue. Let it sit overnight and check it again, if much lower, the battery is toast. Best of luck. We can help with the charging system if it is the issue. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
