The advice about getting looped rims is the best answer, but you ask so here it comes. The old loops can be removed from the old rims using a combination of a grinder, cold chisel, and/or cutting torch. If you can't manage to get the old loops off and cleaned up you do not need to be installing the old loops on a new rim. (Never torch or weld a rim with a tire in place inflated or not if you wish to live a long life.) Be sure the old rivets are ground smooth. With the rivets ground and drilled out you could consider mounting the loops to the new blank rims with new rivets . . . but you ask about welding. Arc weld using nickel/cadmium rods specially designed for welding cast iron. It will bond to the black steel but the bond will not be as strong as a steel to steel weld. I have done it and it works. By the way have your loops bolted to the cast centers when you place the tack weld or drill the rivet holes.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
