Re: Is there a better way?
Posted by mkirsch on April 30, 2013 at 05:27:01 from (64.80.110.75):
In Reply to: Is there a better way? posted by hayfarmer on April 29, 2013 at 19:36:12:
I use a vinyl tube that fits down inside the pipe with room to spare to pump the oil in out of a gallon jug. Oil goes in the tube, air escapes around the tube, and you can pump directly into the fill hole and see when it's full.
