Re: 400 cyclo 30 rows?
Posted by John A. on April 30, 2013 at 06:36:44 from (64.128.16.238):
In Reply to: 400 cyclo 30 rows? posted by Thad Barker on April 30, 2013 at 04:08:59:
Thad, Loosen up the Row Units mounts and slide inward I do not think it will be a problem.
Start at the Center line of the planter and measure outward, loosening up the Row units and gauge/drive wheels. You will need to shorten the drive rod comming of the gauge wheel going to the Center Unit/grain tank. If memory serves it is a rod and tube just unpin and find a hole closer in. Hope this helps.
Later,
John A.
