Re: Does the M have enough power.
Posted by gbs on April 30, 2013 at 17:42:59 from (64.234.38.41):
In Reply to: Does the M have enough power. posted by truckerlary on April 30, 2013 at 16:58:57:
i ran a 1207 jd with an h it turned it ok only problem was the pencil size lift cylinder on the cutter required more pressure than the h had to lift it properly,what i was cutting was medium thickness waist high sudan-sorghum,i used the same cutter with a larger tractor to cut some other crops the h would have struggled with
