The spindle bearings (top and bottom of the vertical tube at the end of each axle.) are bushings. The bottom of the spindle is located by a thrust bearing that keeps the wheel hub down, and the spindle tube up. If the lubrication of the spindle has been ignored, the spindle will wear the bushings. this wear allows wobble. Check it by jacking the axle till the wheel and tire is off the ground. Block the axle with good cribbing to make it safe. then violently shake the wheel/tire assembly while someone waches the spindle top and bottom to see if there is looseness. Side to side more than 1/16" is about all that is acceptable. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
