806 with injector line leak
Posted by Jbraman on April 30, 2013 at 18:47:05 from (184.158.82.75):
My 806 diesel with a 360 ih engine has a leak on the #1 cylinder right where it connects to the injector. The compression fitting seems to be loose. Can you replace just the fitting or do I need a whole new line?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
