Posted by athol carr on May 01, 2013 at 02:13:48 from (115.188.3.223):
In Reply to: Re: w-14 posted by rustred on April 30, 2013 at 21:29:10:
Your comments are true for the F-12/F-14, 1400 rpm versus 1650 rpm (12 versus 14 HP). The O-12 and O-14, I-12 and I-14 and Fairway-12 and Fairway-14 all had 2000 rpm engine speeds. The O-12 engine will produce nearly 20 HP at full throttle. The very early W-14 had 1400 rpm engines changed to 1700 rpm to get 3rd gear speed up to a reasonable amount. The W-14 used the same engine governor weights and springs as the F-14, hence 1650 rpm.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
