Posted by wayne in mn on May 01, 2013 at 06:16:49 from (71.8.147.153):
In Reply to: H lift all posted by DTK on May 01, 2013 at 06:02:25:
There is likely some air in the top of the cylinder that acts like a rubber ball, compressing & releasing. Support the loader so each cylinder can be removed one at a time. Extend the removed cylinder and then place the rod end so it is LOWER than the hose end; push the control lever all the way forward to allow the air-oil to enter the pump reservoir as you completely compress the cylinder rod back into the cylinder. Do this a couple times and re-attach the first cylinder; repeat for the opposite side and you should be good to go.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
