Re: Farmall A, Round 3
Posted by gene bender on May 01, 2013 at 12:06:46 from (67.55.226.151):
In Reply to: Farmall A, Round 3 posted by kopeck on May 01, 2013 at 08:49:14:
You need to maka a mark where #1 tower is on the body of the mag. Then remove the cap and check that the rotor stops and clicks on impulse at that mark. If the rotor is off just one tooth they will start hard. I would check that first assuming you do have good fire at the plug. Then the idle circut in the carb mite be plugged also making it hard to start. When everything is good they will fire on the first turn. Plugged aircleaner is another thing to check remove the bottom and check the cup mite be full of junk.
