Posted by rhtx55 on May 01, 2013 at 16:47:02 from (68.185.207.25):
In Reply to: H lift all posted by DTK on May 01, 2013 at 06:02:25:
It's called a retarder valve, you can use this or simply place an orifice in the line going back to the reservoir to reduce the flow of oil.
For example If you have a 1/2 inch fitting plumbed into the reservoir use a fitting that has a hole size of 3/8 or 1/4 orifice, keep going down in size until you have the reduced motion you desire.
The only drawback will be the lines plumbed from the cylinder(s) to the reservoir must be in top shape or they will blow out under the pressure of the reduced flow of the return line.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
