Re: gas fouling # 4 plug
Posted by Greg K on May 01, 2013 at 17:07:25 from (75.104.160.36):
In Reply to: gas fouling # 4 plug posted by Bob Reineke on May 01, 2013 at 12:17:27:
I have an M that will do that on #4 also. I always wondered if it had something to do with the fact that #4 plug wire was on the bottom and either had a bit of water allowing the spark to get away or the distributer was sore and #4 took the hit. Mine will do it if I use the choke too soon, but it is always #4, even after I changed plugs, wires, cap, rotor, points, checked the valves, compression, and valve seals. If you find out what the problem is let me know. :)
