No Hy-Tran use 90wt. The level plug is behind the left brake rod. Final drive fill to 1 inch below the fill plug. You should drain the old stuff out of the tranny then put a gal of Diesel in and drive around a little to get a good flush. You can add some new lube in the pto but it will fill to desired level after driving as there is a channel in the tranny that drains to the pto.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
