Re: Farmall A, Round 3
Posted by mkirsch on May 02, 2013 at 05:02:17 from (64.80.110.75):
In Reply to: Farmall A, Round 3 posted by kopeck on May 01, 2013 at 08:49:14:
If you didn't mess with it between the time it was running good, and then suddenly not running good, then it is probably not off a tooth.
These things don't just spontaneously "jump time" with no apparent damage. Everything is gear driven, so the only way to be a tooth off is to take it apart and purposely move things over one tooth. Otherwise, the gear is stripped, and that would be painfully obvious.
