Re: Should I use Hy-Tran?
Posted by jkmdg84 on May 02, 2013 at 08:03:34 from (170.54.58.4):
In Reply to: Re: Should I use Hy-Tran? posted by buzzinduzzin on May 01, 2013 at 18:40:02:
So should a person be trying to find some of the SAE 90 oil? A lot of the 80W90 and 85W140 that you can buy is GL5 rated.
