Re: H will run a day after fuel shut off until tractor quits
Posted by Jim Becker on May 02, 2013 at 09:01:23 from (173.74.120.222):
In Reply to: H will run a day after fuel shut off until tractor quits. posted by Alan in VA on May 02, 2013 at 06:42:33:
If you want to test everyone's theory, try this.
1) Shut it off your usual way, letting it starve out after shutting the fuel off.
2) Go out the next day and start it without opening the fuel. Let it run the 10 seconds or so until it quits. Leave it that way.
3) Go out the next day and try again. If it runs for another 10 seconds, you probably have a leaking shut-off valve. If not, it was running on residual fuel in the system.
