Re: H will run a day after fuel shut off until tractor quits.
Posted by old on May 02, 2013 at 09:48:47 from (209.86.226.40):
In Reply to: H will run a day after fuel shut off until tractor quits. posted by Alan in VA on May 02, 2013 at 06:42:33:
That is normal. When the engine shuts down after you turn the gas off there is still a little bit of gas in the lines and carb. So when you try to restart it it fires on that small amount of gas that is still in the carb. Just to prove it try this. After you shut the engine down let it sit say an hour then go back and pull the carb drain plug and you will find the carb has some gas in it
