Re: H will run a day after fuel shut off until tractor quits.
Posted by wayne in mn on May 02, 2013 at 11:42:22 from (64.118.12.213):
In Reply to: H will run a day after fuel shut off until tractor quits. posted by Alan in VA on May 02, 2013 at 06:42:33:
I do not know why you want to run the carb dry each time you use the tractor. Is the ignition switch non-functional?
Just idle the engine down, put the transmission in 5th gear, step on the brakes, and let out the clutch? Then shut off the gas at the sediment bowl.
Your tractor will be ready to go next time and you can drive for about a minute before remembering to turn the gas back on!
